It is currently Tue Aug 12, 2025 2:28 am
PostPosted: Mon Apr 18, 2016 5:58 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Can I chuck a bullnose router bit in a drill press? No major stressors. 1/4" hole in softwood.
Thanks in advance
PostPosted: Mon Apr 18, 2016 6:07 pm
If you can drill a small pilot hole it would help, as there's no cutting speed at the center of the bit as the diameter is zero.
That said , if it's a shallow hole or you back the cutter out frequently I'd bet you'd get away with it.
PostPosted: Mon Apr 18, 2016 6:31 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Like Jim suggests, a pilot hole, and clamp the board down to the DP table, just to be safe.
Alex
PostPosted: Mon Apr 18, 2016 7:22 pm
Drilling with router bits? Plunge routers do it all the time, and without a pilot hole. Regular routers can also do plunge cuts if small bits and a firm grip is used, by placing one edge of the base on the work and slowly tilting the router into the rout (some experience necessary).
Drill presses don't have the RPM's of the typical router, so a bit that has an angled flute may give a better result. The "twist" in a drill bit improves the shearing action of the cutter.
PostPosted: Mon Apr 18, 2016 7:50 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I agree with Clay. Also, owing to the relatively slow speed of the drill press the resulting hole
probably wouldn't be any cleaner than a brad point drill bit, if that's what you're after. You could
try it and see though, it won't do any harm.
Ken
PostPosted: Tue Apr 19, 2016 7:53 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
Why not just use a Forstner bit? I mean, other than the reason that you don't have one handy and have a router bit lying on your workbench.
PostPosted: Tue Apr 19, 2016 11:12 pm
First name: Roger
State: Oklahoma
I've created depressions for control knobs in this manner several times. As was said above though, drill press rpms aren't high enough for router bits, so the holes aren't nearly as clean. It's not the ideal way to do things, but it does work.
PostPosted: Tue Apr 19, 2016 11:43 pm
Last Name: Shanklin
City: Windsor
State: ON
I do it all the time Steve.
Bob
PostPosted: Wed Apr 20, 2016 8:37 am
Not the best for centering accuracy but it will work -- peck drill to clear the chips. Can I ask why this is your tool of choice?
Ken Cierp
PostPosted: Wed Apr 20, 2016 8:40 am
Last Name: Denvir
City: Baltimore
State: ON
Hey Ken, I want to use a bullnose bit to create a rounded depression.
Actually, probably the opposite of a bullnose bit, but you know what I mean :-)
PostPosted: Wed Apr 20, 2016 8:43 am
First name: Charlton
Last Name: Wang
Cove bit?
Sent from my MotoG3 using Tapatalk
PostPosted: Wed Apr 20, 2016 9:02 am
Last Name: Denvir
City: Baltimore
State: ON
Yep. Thanks Charlton.
PostPosted: Wed Apr 20, 2016 9:53 am
Why not - a cutting edge is, well, a cutting edge. If it is employed in a less than optimal manner, such as using a router bit on a drill press, make sure it is sharp, take your time and test on some scrap. I'll chuck just about anything in a drill press if it will cut the shape I want and won't throw the chuck out of balance.
PostPosted: Wed Apr 20, 2016 1:50 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Necessity is the mother of invention as they say and if I had to do this I would
first drill a hole short of final depth with a forstner, then follow with the cove/fluting bit,
stock clamped to avoid vibration and get best surface finish.
Ken
PostPosted: Wed Apr 20, 2016 6:01 pm
yep .. have done like Roger a few times Steve ... cove or bowl cutting bit in the drill press .... clamp the work, go slow, works like a charm
PostPosted: Sat Apr 23, 2016 9:04 am
The router bit will probably do fine for what you want. A rosette cutter could also work, and one with insert knives would allow you to grind a custom profile.
http://www.mlcswoodworking.com/shopsite ... osette.htm
Users browsing this forum: meddlingfool and 39 guests
cron
